motor ve epc ışığının yanık kalması
  • Konbuyu başlatan Konbuyu başlatan cmltryk
cmltryk
12 Ağu 2016
Cemil
merhabalar geçenlerde motor ve epc ikaz lambası sönmemişti servise götürdüğümde yakıttandır dediler yakıt kelebeğini temizlediler sorun ortadan kalkmıştı 1 ay sonra tekrar arıza verdiğinde vag kablo ile tarama yaptığımda aşağıdaki hataları aldım.Bilgisi deneyimi olan arkadaşlardan konu ile ilgili yardımlarını bekliyorum
5 FaultsFound:
2813 - Accelerator Position Sensor (G79)
          P2122 00 [032] -SignaltooLow
Intermittent - Not Confirmed - Tested Since Memory Clear
FreezeFrame:
FaultStatus: 00000001
FaultPriority: 2
FaultFrequency: 1
Mileage: 24762 km
Date: 2019.11.02
                    Time: 14:43:20
                    Engine speed: 0.00 /min
Normedloadvalue: 0.0 %
Vehiclespeed: 0 km/h
Coolanttemperature: 96 °C
Intakeairtemperature: 32 °C
Ambientairpressure: 1010 mbar
Voltage terminal 30: 12.604 V
Unlearningcounteraccording OBD: 23
Outsideairtemperature: 12 °C
Absoluteintakepressure: 101 kPaabs
                    Engine torque: 13.2 Nm
Fuellevel: 45.00 l
2815 - Accelerator Position Sensor 2 (G185)
          P2127 00 [032] -SignaltooLow
FreezeFrame:
FaultPriority: 2
FaultFrequency: 1
Mileage: 24762 km
Date: 2019.11.02
                    Time: 14:43:20
Fuellevel: 45.00 l
4166 -ManifoldPressure / Boost Sensor (G31)
          P0238 00 [032] -Signaltoo High
FreezeFrame:
FaultPriority: 2
FaultFrequency: 1
Mileage: 24743 km
Date: 2019.11.02
                    Time: 14:23:05
Coolanttemperature: 88 °C
Intakeairtemperature: 45 °C
Voltage terminal 30: 12.345 V
Chargeairpressure: actualvalue: 3227.34 hPa
Intakemanifoldpressurerawvalue: 1014.14 hPa
Overruncut-off-Bit 0: 0
Throttlevalveadapter: actualvalue: 6.25 %
20572 -IntakeAirTemp. Sensor (G42)
          P0113 00 [032] -Signaltoo High
FreezeFrame:
FaultPriority: 2
FaultFrequency: 1
Mileage: 24743 km
Date: 2019.11.02
                    Time: 14:23:11
Outsideairtemperature: 16 °C
                    Engine torque: 0.0 Nm
Fuellevel: 46.00 l
16434 -ChargePressure Control Actuator
          P334B 00 [232] -MechanicalMalfunction
          MIL ON -Intermittent - Confirmed - Tested Since Memory Clear
FreezeFrame:
FaultPriority: 2
FaultFrequency: 5
Mileage: 24730 km
Date: 2019.11.02
                    Time: 13:38:32
                    Engine speed: 1463.50 /min
Normedloadvalue: 50.2 %
Vehiclespeed: 21 km/h
Coolanttemperature: 51 °C
Intakeairtemperature: 6 °C
Ambientairpressure: 1000 mbar
Voltage terminal 30: 14.701 V
Unlearningcounteraccording OBD: 40
Chargepressureactuator: specifiedposition: 140.00 %
                    Bypass valve f highpressturbochturbine inlet: actualvalue: 94.30 %
Chargepressureactuator: adaptationforlower stop: 3025.6 mV
                    Bypass valveforhighpressturbochargerturbine inlet: status-Bit 0: 0
                    Bypass valveforhighpressturbochargerturbine inlet: status-Bit 16: 0
                    Bypass valveforhighpressturbochargerturbine inlet: status-Bit 24: 0
Gaz kelebeği arıza vermiş servis tekrardan baksın garantili işe değişim yaparlar geçmiş olaun
Akünüzü yetkili serviste düzgünce VAS6161 ile test ettirip önce onun durumunu netleştirin isterseniz. Aynı anda birden çok sensör arızası vermesi akü/sarj ihtimalini belirtiyor olabilir.
Date: 2019.11.02 Time: 14:43:20 Voltage terminal 30: 12.604 V
Date: 2019.11.02 Time: 14:23:11 Voltage terminal 30: 12.345 V
Date: 2019.11.02 Time: 13:38:32 Voltage terminal 30: 14.701 V
