Kapı altı ambianslarının kodlamada hata vermesi
Recep_Gul
Paylaşımcı Üye
14 Tem 2018
Berlin
Recep
Arkadaşlar merhaba, dün kapı altı ışıklarını monte edip kodlamasını yapmıştım,az önce pc yi araca bağlayıp "Auto-Scan" yaptıktan sonra "Address 42: Door Elect, Driver" ve "Address 52: Door Elect, Pass." kanallarında hata olarak görüyor. Bunun bi sakıncası varmıdır ?
Hata kodlarını aşağıda paylaşıyorum;
Tuesday,21,January,2020,18:52:57:00007
VCDS Version: Release 18.9.0 (x64) Running on Windows 10 x64
www.Ross-Tech.com
                Address 52: Door Elect, Pass.       Labels: 5QX-959-X92-52.clb
Control Module Part Number: 5Q0 959 592 E    HW: 5Q0 959 592 B
  Component and/or Version: TSG BFS       020 0041
           Software Coding: 003E00208E00040000801000
            Work Shop Code: WSC 01357 011 00200
              ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003 (VW37)
                       ROD: EV_DCUPasseSideEWMAXCONT.rod
                      VCID: 428BFC09D58FD65A83-8016
2 Faults Found:
65799 - Door Warning / Enrty Lighting
          B1775 01 [008] - Electrical Failure
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 3
                    Fault Frequency: 5
                    Reset counter: 21
                    Mileage: 41945 km
                    Date: 2020.01.20
                    Time: 12:20:48
65649 - Lamp for Ambient Illumination
          B1325 13 [008] - Open Circuit
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 21
                    Mileage: 41888 km
                    Date: 2020.01.17
                    Time: 18:21:04
Tuesday,21,January,2020,18:52:16:00007
www.Ross-Tech.com
                Address 42: Door Elect, Driver       Labels: 5QX-959-X93-42.clb
Control Module Part Number: 5Q0 959 593 E    HW: 5Q0 959 593 B
  Component and/or Version: TSG FS        020 0041
           Software Coding: 003E02208000040000001000
              ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003 (VW37)
                       ROD: EV_DCUDriveSideEWMAXCONT.rod
                      VCID: 4385F90DCA95DF5288-8016
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 21
                    Mileage: 41945 km
                    Date: 2020.01.20
                    Time: 12:47:59
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 21
                    Mileage: 41945 km
                    Date: 2020.01.20
                    Time: 12:58:06
Sistemde kısa devre tespiti var. + ve - nereden aldınız acaba ? Parçalar orjinal mi yoksa Logo lu kapı altı aydınlatmamı ?
