OBDELEVEN BAZI KODLAMALAR
15 Nis 2020
Yusuf
Bazı kodlar buldum belki yararlı olur sizlere. OBDELEVEN ile ilgili.
OBDELEVEN KODLAMALARI
Ambiyans Aydınlatma:
Central Electric - Adaptation - Interior light, light configuration
Ambiantemenue mit globalem aus
not active – active
Ambiantemenue mit alle Zonen
not active – active
Central Electric - Adaptation - Ambient Light Colour List
RGB 255,0,0
Gösterge Ekran Teması:
Dash Board - Adaptation - Display Depiction Change Version
Offroad Menüsü ve Driving School Mode:
Multimedia - Adaptation - Car_Function_List_BAP_Gen2
compass_0x15
not active àactive
Multimedia - Adaptation - Car_Function_Adaptations_Gen2
menu_display_compass
not active àactive
menü_display_compass_over_thres_hold_high
not active - active
menu_display_driving_school
not active - active
menü_display_driving_school_over_thres_holding_high
not active - active
Sesli Onay:
Central Electric - Adaptation - Acknowledgement Signals
Akustische Rueckmeldung Global
not active - active
Akustische Rueckmeldung Entriegeln
not active - active
Akustische Rueckmeldung Verriegeh
not active - active
Akustische Rueckmeldung Signalhorn
not active - active
Start-Stop Işığının Yanıp Sönmesi:
Start System Interface - Adaptation - Developer Coding : Searchlights
ZAT_illumination_modus_mybeat_clamp58xt
not active - active
ZAT_illumination_concept_mybeat_clamp58xt
not active - active
Aracı Kapatırken Işıkların Yavaş Sönmesi:
Central Electric - Adaptation - Suchbeleuchtung_allgemein
KL58 Einschaltenmit Rampe
Not active - active
Araç Açılıp Kapatılınca Sinyal Hızı:
ZV_Blinken_Hellzcit,Dunkelzeit,Abschulss
normal 200ms - fast 50ms - slow 255ms
Amerikan Park:
Central Electric - Adaptation - Leuchte 0 BLK VL B36
Lichtfunktien B0
nicht aktiv - tagfahrlicht
Lichtfunktien C0
Nicht aktiv - standlicht allgemein (Schlusslicht,possition licht, begren )
Dimmwert CD0
%CHANGE
Lichtfunktion E0
Nicht aktiv - Blinkenlinks Dunkelphase
Dimming Direction EF0
Maximize - minimize        sol ( left )
Central Electric - Adaptation - Leuchte 1BLK VRB 20
Light fucktien B1
Nicht aktiv - tagfahrlicht
Licht funktion C1
Nicht aktiv - standlicht allgemein ( schluss licht,positionicht, begren )
Dimmwert CD1
%CHANGE
Licht funktion E1
Nicht aktiv - blinken rechts dunkelphase
Dimming Direction EF1
Maximize - minimize        sağ ( right )
Paylaşım için teşekkürler hocam, ama paylaştığınız kodlamaların bir çoğu kredili sistemde tek tıklama ile zaten mevcut, sadece aracı kapatıp açarken ki sinyal hızları yok bunuda müsait bir günümde deneyeceğim. Tekrar teşekkürler.
Ayrıca, bu kodlamanın kanalını siz vcds ye göre yazmışsınız. Obdeleven de adaptasyon kısmına girdikten sonra Bu yer farklı bir kanalda.
Maalesef vcds kanalları ile obdeleven kanalları aynı yerle de değiller.
4'lü Flaşörlerin hızları bende 300 olarak çıktı, sizin paylaştığınız yazıda normale 200 yazılmış. Sanırım dynamic olmayan Flaşörlerde değer böyle...
@Recep Gül Kredili sistemi kullanmak istemeyenler için paylaşım yaptım. Valla Recep bey Youtube den video izleyerek baktım kodlamalara. Tek tek hepsini not aldım.
@Recep Gül Sizin MK7.5 olduğu için ve Dynamic kayar led olduğu için farklılık gösterebilir. Bilemiyorum ama diğer çoğu aynı gibi.
hocam çok güzel paylaşım elinize sağlık ama obdeleven ile amerikan parkları kapatmak istiyorum nasıl yaparım malum muayene geldi :)
not active – active
not active – active
RGB 255,0,0
compass_0x15
not active àactive
not active àactive
not active - active
not active - active
not active - active
Sesli Onay:
not active - active
not active - active
not active - active
not active - active
not active - active
not active - active
Not active - active
Amerikan Park:
Lichtfunktien B0
Lichtfunktien C0
Dimmwert CD0
%CHANGE
Lichtfunktion E0
Light fucktien B1
Licht funktion C1
Dimmwert CD1
%CHANGE
Licht funktion E1
@ayboay Burada verilen Amerikan Park Açma bölümünden aynı şeyleri yapabilirsiniz. Yani arasında tire (-) bulunan bölümlerin (nicht aktiv - aktiv gibi) hepsini sol taraftaki gibi yapabilirsiniz. Son olarak Dimmwert CD0 ve Dimmwert CD1 leri 0 ‘ a almanız gerekmektedir.
Doğrudur hocam, Bugün kodlamayı yaptım. Teşekkür ettim. Kodlamalar listesine bir kodlama daha ekledim sayenizde. Standart hız 300 olarak ayarlıydı. Bende aracı kilitleyince sesli onay vardı, ufak bi senkranizasyon sorununu vardı o sorunuda 300 değerini  250 yaparak halletmiş oldum, sesli onay ile birlikte aynı anda yanıyor 4'lüler.
@Recep Gül İşe yaradıysa ne mutlu bana. Rica ederim. ObdEleven üstünden Lane Assist' i açmanın yolunu da buldum fakat adam ispanyolca konuşuyor. Cihazım gelsin. Ayın 14 ünde verdim sipariş ObdEleven ama hala elime ulaşmadı.
Gösterdiği adımları izledikten sonra Türkçe'ye çeviririz hocam sıkıntı yok :)
Siparişin son durumunu öğrenebiliyor musunuz? Gümrüğe mi takıldı acaba?
@Recep Gül Haha 😂 Dün gümrüğe girmiş tam 14 gün sonra. İnşallah 2-3 haftaya alacağım. Yalnız bir kaç yere sordum kameraya data dosyası yüklenmesi gerekiyormuş. Direk açarsan çalışmıyor deniliyor. Yani bugün bir kaç yerle konuştum bana öyle söylediler
Bu cihazla veya vcds ile video oynatma kodlaması yapılabiliyor mu?
