- 20 Ara 2019
- Erinç
Her 100'lük dd diliminde Beygir Gücü / Tork değerleri:
1000 rpm: 172.8 Nm / 127.4 lb-ft / 18.1 kW / 24.6 PS / 24.2 hp
1100 rpm:200.6 Nm / 147.9 lb-ft / 23.1 kW / 31.4 PS / 31 hp
1200 rpm:222.2 Nm / 163.9 lb-ft / 27.9 kW / 38 PS / 37.4 hp
1300 rpm:237.7 Nm / 175.3 lb-ft / 32.4 kW / 44 PS / 43.4 hp
1400 rpm:246.9 Nm / 182.1 lb-ft / 36.2 kW / 49.2 PS / 48.5 hp
1500 rpm:250 Nm / 184.4 lb-ft / 39.3 kW / 53.4 PS / 52.6 hp
1600 rpm:250 Nm / 184.4 lb-ft / 41.9 kW / 57 PS / 56.1 hp
1700 rpm:250 Nm / 184.4 lb-ft / 44.5 kW / 60.5 PS / 59.6 hp
1800 rpm:250 Nm / 184.4 lb-ft / 47.1 kW / 64.1 PS / 63.1 hp
1900 rpm:250 Nm / 184.4 lb-ft / 49.7 kW / 67.7 PS / 66.7 hp
2000 rpm:250 Nm / 184.4 lb-ft / 52.4 kW / 71.2 PS / 70.2 hp
2100 rpm:250 Nm / 184.4 lb-ft / 55 kW / 74.8 PS / 73.7 hp
2200 rpm:250 Nm / 184.4 lb-ft / 57.6 kW / 78.3 PS / 77.2 hp
2300 rpm:250 Nm / 184.4 lb-ft / 60.2 kW / 81.9 PS / 80.7 hp
2400 rpm:250 Nm / 184.4 lb-ft / 62.8 kW / 85.5 PS / 84.2 hp
2500 rpm:250 Nm / 184.4 lb-ft / 65.5 kW / 89 PS / 87.7 hp
2600 rpm:250 Nm / 184.4 lb-ft / 68.1 kW / 92.6 PS / 91.2 hp
2700 rpm:250 Nm / 184.4 lb-ft / 70.7 kW / 96.1 PS / 94.7 hp
2800 rpm:250 Nm / 184.4 lb-ft / 73.3 kW / 99.7 PS / 98.2 hp
2900 rpm:250 Nm / 184.4 lb-ft / 75.9 kW / 103.3 PS / 101.7 hp
3000 rpm:250 Nm / 184.4 lb-ft / 78.5 kW / 106.8 PS / 105.2 hp
3100 rpm:250 Nm / 184.4 lb-ft / 81.2 kW / 110.4 PS / 108.8 hp
3200 rpm:250 Nm / 184.4 lb-ft / 83.8 kW / 113.9 PS / 112.3 hp
3300 rpm:250 Nm / 184.4 lb-ft / 86.4 kW / 117.5 PS / 115.8 hp
3400 rpm:250 Nm / 184.4 lb-ft / 89 kW / 121.1 PS / 119.3 hp
3500 rpm:250 Nm / 184.4 lb-ft / 91.6 kW / 124.6 PS / 122.8 hp
3600 rpm:249.8 Nm / 184.2 lb-ft / 94.2 kW / 128.1 PS / 126.2 hp
3700 rpm:249.3 Nm / 183.8 lb-ft / 96.6 kW / 131.4 PS / 129.4 hp
3800 rpm:248.4 Nm / 183.2 lb-ft / 98.9 kW / 134.4 PS / 132.5 hp
3900 rpm:247.2 Nm / 182.3 lb-ft / 101 kW / 137.3 PS / 135.3 hp
4000 rpm:245.6 Nm / 181.1 lb-ft / 102.9 kW / 139.9 PS / 137.9 hp
4100 rpm:243.6 Nm / 179.6 lb-ft / 104.6 kW / 142.2 PS / 140.2 hp
4200 rpm:241.3 Nm / 177.9 lb-ft / 106.1 kW / 144.3 PS / 142.2 hp
4300 rpm:238.6 Nm / 176 lb-ft / 107.4 kW / 146.1 PS / 144 hp
4400 rpm:235.6 Nm / 173.7 lb-ft / 108.6 kW / 147.6 PS / 145.5 hp
4500 rpm:232.3 Nm / 171.3 lb-ft / 109.5 kW / 148.9 PS / 146.7 hp
4600 rpm:228.4 Nm / 168.4 lb-ft / 110 kW / 149.6 PS / 147.4 hp
4700 rpm:223.5 Nm / 164.8 lb-ft / 110 kW / 149.6 PS / 147.4 hp
4800 rpm:218.8 Nm / 161.4 lb-ft / 110 kW / 149.6 PS / 147.4 hp
4900 rpm:214.4 Nm / 158.1 lb-ft / 110 kW / 149.6 PS / 147.4 hp
5000 rpm:210.1 Nm / 154.9 lb-ft / 110 kW / 149.6 PS / 147.4 hp
5100 rpm:206 Nm / 151.9 lb-ft / 110 kW / 149.6 PS / 147.4 hp
5200 rpm:202 Nm / 149 lb-ft / 110 kW / 149.6 PS / 147.4 hp
5300 rpm:198.2 Nm / 146.2 lb-ft / 110 kW / 149.6 PS / 147.4 hp
5400 rpm:194.5 Nm / 143.5 lb-ft / 110 kW / 149.6 PS / 147.4 hp
5500 rpm:191 Nm / 140.8 lb-ft / 110 kW / 149.6 PS / 147.4 hp
5600 rpm:187.6 Nm / 138.3 lb-ft / 110 kW / 149.6 PS / 147.4 hp
5700 rpm:184.3 Nm / 135.9 lb-ft / 110 kW / 149.6 PS / 147.4 hp
5800 rpm:181.1 Nm / 133.6 lb-ft / 110 kW / 149.6 PS / 147.4 hp
5900 rpm:178 Nm / 131.3 lb-ft / 110 kW / 149.6 PS / 147.4 hp
6000 rpm:175.1 Nm / 129.1 lb-ft / 110 kW / 149.6 PS / 147.4 hp
6100 rpm:171.5 Nm / 126.5 lb-ft / 109.6 kW / 149 PS / 146.8 hp
6200 rpm:166.7 Nm / 122.9 lb-ft / 108.2 kW / 147.2 PS / 145 hp
6300 rpm:160.7 Nm / 118.5 lb-ft / 106 kW / 144.2 PS / 142.1 hp
6400 rpm:153.6 Nm / 113.3 lb-ft / 102.9 kW / 140 PS / 137.9 hp
6500 rpm:145.4 Nm / 107.2 lb-ft / 99 kW / 134.6 PS / 132.6 hp
