VagCom Kodlarını Eski Haline Getirmek
  • Konbuyu başlatan Konbuyu başlatan pilot
pilot
30 May 2021
pilot
Work shop code değiştirilebilirmi?
Sunday,30,May,2021,10:52:22:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.2.0 (x64)
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: VSSZZZ1PZDR013794   License Plate:
Chassis Type: 1P-SE35 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 55 56 62 72
          77
VIN: VSSZZZ1PZDR013794   Mileage: 103020km-64013miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 LJ    HW: 03L 906 023 KL
   Component: R4 1.6l TDI   H43 9978
   Revision: --H43---    Serial number:
   Coding: 00254036032400080000
           00254016032400080000 ESKİSİ BU KOD
   Shop #: WSC 06402 785 00200
   ASAM Dataset: EV_ECM16TDI02103L906023LJ 003014
   ROD: EV_ECM16TDI02103L997557A.rod
   VCID: 79F958E3F8D95B4E54-802C
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans        Labels: 0AM-927-769.clb
   Part No SW: 0AM 300 054 E    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 3630
   Revision: 00043014    Serial number: CU501206286137
   Coding: 0000020
   VCID: 2F6DA6BBBE1D45FEBA-807A
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BL    HW: 1K0 907 379 BL
   Component: ESP MK60EC1   H31 0152
   Revision: 00H31001
   Coding: 113B2012092300FD881204ED901D0041350800
   Shop #: WSC 04941 000 00000
   VCID: 7DF14CF3E4F1676E78-8028
Address 08: Auto HVAC (J255)       Labels:| 5K0-907-044.clb
   Part No SW: 5P0 907 044 R    HW: 5P0 907 044 R
   Component: Climatronic   H18 0804
   Revision: 00001001
   Coding: 0000000002
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_ClimaAutoBasis_SE35.rod
   VCID: 3F8DF6FBA67DB57E2A-806A
Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb
   Part No SW: 5K0 937 087 R    HW: 5K0 937 087 R
   Component: BCM PQ35 H    021 0068
   Revision: BE021001
   Coding: 46190A7F487B0EC042080080950089C447750008727D8560008040240040
           40180A3E80250CC042080080950089C442550008727D8160008040000040 ESKİSİ BU KOD
   Shop #: WSC 04941 123 12345
           WSC 04941 000 00000 ESKİSİ BU KOD
   VCID: 4487F917C79BD6A677-8010
   Subsystem 1 - Part No: 1P0 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 02071  26  0611
   Coding: 00DF90
                 00DB90 ESKİSİ
   Subsystem 2 - Part No SW: 1P0 955 559 A    HW: 1P0 955 559 A  Labels: 1P0-955-559.CLB
   Component: REGENLICHTSEN  H04 0003
   Coding: 07542E
           02542E ESKİSİ
1 Fault Found:
02092 - Enabling Heated Seat
            009 - Open or Short to Ground
             Freeze Frame:
                    Fault Status: 01101001
                    Fault Priority: 5
                    Fault Frequency: 8
                    Reset counter: 75
                    Mileage: 103020 km
                    Time Indication: 0
                    Date: 2015.10.20
                    Time: 19:49:54
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.10 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
ESKİSİ BU KOD
6 Faults Found:
01504 - Bulb for License-Plate Light (X)
            007 - Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00100111
                    Fault Priority: 2
                    Fault Frequency: 12
                    Reset counter: 84
                    Mileage: 102296 km
                    Time Indication: 0
                    Date: 2015.08.28
                    Time: 10:03:49
             Freeze Frame:
                        Term 15 On
                    Voltage: 14.05 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 2
                    Fault Frequency: 11
                    Reset counter: 84
                    Mileage: 102296 km
                    Time Indication: 0
                    Date: 2015.08.28
                    Time: 09:58:21
             Freeze Frame:
                        Term 15 On
                    Voltage: 14.25 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01800 - Light Switch (E1)
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 3
                    Fault Frequency: 4
                    Reset counter: 82
                    Mileage: 102207 km
                    Time Indication: 0
                    Date: 2015.08.24
                    Time: 09:42:31
             Freeze Frame:
                        Term 15 Off
                    Voltage: 12.85 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 82
                    Mileage: 102239 km
                    Time Indication: 0
                    Date: 2015.08.24
                    Time: 17:22:02
             Freeze Frame:
                        Term 15 Off
                    Voltage: 12.70 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
02394 - Parking Light Left Front (M1)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 77
                    Mileage: 102117 km
                    Time Indication: 0
                    Date: 2015.08.15
                    Time: 11:54:18
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.20 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
02395 - Parking Light Front Right (M3)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 77
                    Mileage: 102117 km
                    Time Indication: 0
                    Date: 2015.08.15
                    Time: 11:52:02
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.85 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 10: Park/Steer Assist (J446)       Labels:. 3C8-919-475.clb
   Part No SW: 5P0 919 475 B    HW: 8P0 919 475 M
   Component: PARKHILFE 4K  H08 0008
   Revision: --------    Serial number: 36861216900296
   Coding: 100101
                  000101 ESKİSİ
           WSC 04941 000 00000 eskisi
   VCID: 3A7B87EFB55F90561D-806E
BUNLAR ESKİSİNDE YOK
2 Faults Found:
00532 - Supply Voltage B+
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 113
                    Mileage: 103009 km
                    Time Indication: 0
                    Date: 2015.10.20
                    Time: 11:20:12
             Freeze Frame:
                    Temperature: 23.0°C
00446 - Function Limitation due to Under-Voltage
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 113
                    Mileage: 103009 km
                    Time Indication: 0
                    Date: 2015.10.20
                    Time: 11:19:22
             Freeze Frame:
                    Temperature: 23.0°C
Address 15: Airbags        Labels: 5N0-959-655.lbl
   Part No SW: 5N0 959 655 AA    HW: 5N0 959 655 AA
   Component: J234__A0A VW10 HI   2118
   Revision: 24017000    Serial number: 003L7PD8UQTX
   Coding: 0012353
   VCID: 7CF741F73FEB6E664F-8028
   Subsystem 1 - Serial number: 6332MTS601581662
   Subsystem 2 - Serial number: 6342MTS602641712
   Subsystem 3 - Serial number: 6351HTS6CSRA6BKR
   Subsystem 4 - Serial number: 6361HTS6BEF96BKJ
   Subsystem 5 - Serial number: 00000000000000000
   Subsystem 6 - Serial number: 00000000000000000
ESKİSİNDE YOK
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 113
                    Mileage: 103009 km
                    Time Indication: 0
                    Date: 2015.10.20
                    Time: 11:19:19
Address 16: Steering wheel (J527)       Labels:| 5K0-953-569.clb
   Part No SW: 5K0 953 521 AT    HW: 5K0 953 569 B
   Component: LENKS.MODUL   014 0140
   Revision: FF010041    Serial number: 20120616102017
   Coding: 188A160002
                 188A140002 ESKİSİ
   ASAM Dataset: EV_SMLSNGVOLWSXS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7EF34BFFE1F77C7661-802A
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 1P0 959 538 D    HW: 1P0 959 538 D  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAP  H02 0103
   Coding: E20000
2 Faults Found:
114178 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 113
                    Mileage: 103009 km
                    Date: 2021.05.29
                    Time: 11:19:54
136194 - Supply voltage
          U1011 00 [008] - Voltage too Low
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 113
                    Mileage: 103009 km
                    Date: 2021.05.29
                    Time: 11:19:49
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 1P0 920 850 N    HW: 1P0 920 850 N
   Component: KOMBI         H03 0705
   Coding: 110F01
   Shop #: WSC 131071 1023 2097151
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
   ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
   VCID: 377D9EDB8E4D8D3EE2-8062
ESKİSİNDE YOK
1 Fault Found:
13635840 - Supply voltage
          [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 113
                    Mileage: 103009 km
                    Date: 2021.05.29
                    Time: 11:21:06
Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 R    HW: 7N0 907 530 H
   Component: J533  Gateway H42 1632
   Revision:   H42       Serial number: 250612F6000268
   Coding: 350202
   VCID: 3F8DF6FBAE7DB57E2A-806A
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H03 0705
   Serial number:
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709
   ROD: EV_Immo_UDS_VDD_RM09_VW31.rod
   VCID: 6ADB77AF8D7FE0D6AD-803E
Address 2E: Media Player 3 (J650)       Labels:. 5N0-035-342.lbl
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662977575
   Coding: 020100
                 010100 ESKİSİ
   VCID: 2A5BB7AF45FF20D66D-807E
ESKİSİNDE BUNLAR YOK
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 113
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 113
                    Mileage: 0 km
                    Time Indication: 0
01044 - Control Module Incorrectly Coded
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 74
                    Mileage: 103020 km
                    Time Indication: 0
                    Date: 2015.10.20
                    Time: 15:12:53
Address 42: Door Elect, Driver (J386)       Labels:| 3C0-959-70X-GEN4.clb
   Part No SW: 3C8 959 701     HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0507
   Revision: 12110009    Serial number: 0004979313
   Coding: 0010B0
   ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
   ROD: EV_TSGFPQ35BRFVW46X_VW32.rod
   VCID: 6DD17CB3BC91F7EEC8-8038
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703 E    HW: 3C0 959 795 E  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  008 1501
   Serial number: 00000006838596
   Coding: 000090
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 65     3305
   Revision: 00H22000
   VCID: 377D9EDB464D8D3EE2-8062
Address 52: Door Elect, Pass. (J387)       Labels:| 3C0-959-70X-GEN4.clb
   Part No SW: 3C8 959 702     HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0507
   Revision: 14110009    Serial number: 0004911949
   Coding: 0010B0
   ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
   ROD: EV_TSGBPQ35BRFVW46X_VW32.rod
   VCID: 6ED37BBFB1970CF6F1-803A
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704 E    HW: 3C0 959 794 E  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  008 1501
   Serial number: 00000006850690
   Coding: 000090
ESKİSİNDE YOK
1 Fault Found:
66048 - Motor for Front Window Regulator
          B11EC 54 [008] - Missing Calibration / Basic Setting
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 114
Address 55: Headlight Range        Labels: 5M0-907-357-V2.lbl
   Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
   Component: AFS-Steuergeraet    0148
   Revision: 00H04000    Serial number:
   Coding: 2556933
   VCID: 3467A9D7573B6626C7-8060
   Subsystem 1 - Part No: 7L6 941 329 C  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    0004
   Coding: 00000039
   Subsystem 2 - Part No: 7L6 941 329 C  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0004
   Coding: 00000039
ESKİSİNDE YOK
1 Fault Found:
02988 - Left-Hand/Right-Hand Traffic Switchover Active
            000 - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 74
                    Mileage: 103020 km
                    Time Indication: 0
                    Date: 2015.10.20
                    Time: 19:09:04
             Freeze Frame:
                    Voltage: 12.07 V
                    Speed: 0.0 km/h
                        ABS 1
Address 56: Radio (J503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 5P0 035 186 B    HW: 5P0 035 186 B
   Component: Media2.0      004 0082
   Revision: 00000001    Serial number: SEZ1Z3M5074535
   Coding: 01060400040000
   VCID: 2E53BBBF79174CF6B1-807A
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 113
                    Mileage: 103009 km
                    Time Indication: 0
                    Date: 2015.10.20
                    Time: 11:19:23
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 113
                    Mileage: 103009 km
                    Time Indication: 0
                    Date: 2015.10.20
                    Time: 11:20:09
Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007662907481
   Coding: 1000000000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3A7B87EFBD5F90561D-806E
3 Faults Found:
ESKİSİNDE BU YOK
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 113
                    Mileage: 103009 km
                    Date: 2021.05.29
                    Time: 11:21:07
0022 - Radio
          U1066 00 [008] - No Communication
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 4
                    Reset counter: 148
                    Mileage: 96753 km
                    Date: 2020.06.09
                    Time: 00:02:04
ESKİSİNDE BU YOK
13893632 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 113
                    Mileage: 103009 km
                    Date: 2021.05.29
                    Time: 11:19:41
Maşallah
:clab:
:clab:
:(n):
Bakınız ilk mesajınızdan sonra size "tanışma bölümünde kendinizi tanıtırsanız seviniriz" denmiş.
Forumun genel kuralıdır; Yeni üyeler ilk önce kendisini ve aracını tanışma bölümünde tanıtır, sonra yardım talep eder, soru sorar.
KASAP vagcom cular bitmedikçe böyle daha çok konu göreceğiz malesef. Yedek alınmadan bodoslama hadi şunuda açayım abi bak şunuda yeni bulduk buda güzel özellik diye diye orjinal kodlar uçuyor.
Geçmiş olsun. Düzeltilmesi için işi bilen bir yere gitmeniz lazım ve o kişide ücreti neyse onu alarak bakar çünkü tüm kod incelenmeli 12-13 tane modül tek tek gözden geçirilmeli.
Aracınızın tüm modüllerini online olarak fabrikasyona çekebiliriz
@forjust1day selam online işini anlamadım nasıl bağlanacağımızı anlatırmısınız.
@forjust1day Address 09,5K0 937 087 R,recoded (Long Coding),from 40180A3E80250CC042080080950089C442550008727D8160008040000040
kırmızı olanlar değişmiş.
:clab:
Elinizde eski kodlar var gibi duruyor kopyalayın yapıştırın aynı bilgisayardan yaptıysanız eskiye dönük kayıtlar bulunur ordan da bakıp düzeltebilirsiniz .
