Multifonksiyon direksiyon hakkında yardım.
  • Konbuyu başlatan Konbuyu başlatan Juxs
Juxs
3 Haz 2022
Yeşilpınar
Berker
Jetta
Merhaba arkadaşlar. Elimde polo 6r multifonksiyon direksiyon var ben buna 5K0963569L zemberek aldım ve arabaya taktım. Fakat kodlama olayında takıldım. Kornam çalışmıyor hiç bir tuş çalışmıyor. Herşeyi doğru taktığımdan eminim. Yardımlarınız için teşekkür ederim.
VIN: WVWZZZ16ZFM014125 License Plate:
Chassis Type: 16-VW32 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ16ZFM014125 Mileage: 39810km-24736miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 1010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CAXA) Labels:. 03C-906-016-CAX2.clb
Part No SW: 03C 906 016 HH HW: 03C 907 309 S
Component: 1.4l R4 TSI X13 8200
Revision: LCX13--- Serial number: 00000000000000
Coding: 00190012000400000000
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM14TFS01103C906016HH 001003
ROD: EV_ECM14TFS01103C906016HH.rod
VCID: 6CD771B7878BFEE6CE-8038
No fault code found.
Readiness: 1110 0100
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: A43B40F8092300FE250C02E6901E0040A5000093
Shop #: WSC 00066 123 12345
VCID: 04073917871B16A626-8050
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 1K8 907 426 HW: 1K8 907 426
Component: AC Manuell H20 0607
Revision: 00001001
Coding: 0010002002
Shop #: WSC 00066 000 00121
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: EV_ACManueBHBVW36X_VW32.rod
VCID: 70EF65C7ABA31A06F2-8024
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 087 AC HW: 5K0 937 087 AC
Component: BCM PQ35 H+ 122 0174
Revision: BF122001
Coding: 20000A3A983F22D440880080040000E407200688508089605C8000000040
VCID: 76E353DFC1C7343628-8022
3 Faults Found:
01134 - Alarm Horn (H12)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 76
Mileage: 39813 km
Time Indication: 0
Date: 2016.10.25
Time: 21:49:22
Freeze Frame:
Term 15 On
Voltage: 12.55 V
ON
ON
OFF
OFF
OFF
01495 - Bulb for High-Beams; Left (M30)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 2
Reset counter: 76
Mileage: 39813 km
Time Indication: 0
Date: 2016.10.25
Time: 23:21:27
Freeze Frame:
Term 15 On
Voltage: 12.40 V
ON
ON
OFF
OFF
OFF
01499 - Bulb for High-Beams; Right (M32)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 76
Mileage: 39813 km
Time Indication: 0
Date: 2016.10.25
Time: 23:21:27
Freeze Frame:
Term 15 On
Voltage: 12.35 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5C0 959 655 F HW: 5C0 959 655 F
Component: AirbagVW10 014 0613
Serial number: 003JQM04FS6.
Coding: 0000504A
Shop #: WSC 00066 000 00148
ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 356194D394417F2EE1-8060
Crash sensor for side airbag: driver side:
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H02 ----
Serial number: 3572MSME446A3D48ZZZ2
Crash sensor for side airbag: front passenger side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H02 ----
Serial number: 3582MSME754F3D47ZZZ9
Crash sensor for side airbag: rear: driver side:
Subsystem 3 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.H H02 ----
Serial number: 3516KSME20030231ZZZ0
Crash sensor for side airbag: rear: passenger side:
Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.H H02 ----
Serial number: 3526KSME2A0F0231ZZZN
1 Fault Found:
9437211 - Igniter for Driver's Airbag
B1000 1B [137] - Resistance Too High
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 39813 km
Date: 2022.06.05
Time: 00:17:10
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 5K0 953 501 BH HW: 5K0 953 569 L
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20111117101201
Coding: 008A140000
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_SMLSNGVOLWS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 71E960C3A0A9130EFD-8024
2 Faults Found:
226839 - Turn Signal Switch
B1144 11 [009] - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 76
Mileage: 39813 km
Date: 2022.06.04
Time: 23:40:13
365080 - Controls in Steering Wheel
U108E 00 [009] - No Communications
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 76
Mileage: 39813 km
Date: 2022.06.04
Time: 23:40:13
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5C6 920 874 HW: 5C6 920 874
Component: KOMBI H04 0906
Coding: 171901
Shop #: WSC 00066 123 00121
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04727
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AP HW: 7N0 907 530 AK
Component: J533 Gateway H57 1653
Revision: H57 Serial number: 21101403000805
Coding: 351002
Shop #: WSC 00066 000 00000
VCID: 7EF34BFFE9F77C7670-802A
2 Faults Found:
01305 - Databus for Infotainment
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 116
Mileage: 39813 km
Time Indication: 0
Date: 2016.10.25
Time: 23:59:41
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 116
Mileage: 39813 km
Time Indication: 0
Date: 2016.10.25
Time: 23:58:25
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 0906
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW31.rod
VCID: 6ADB77AF8D7FE0D6BC-803E
Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0515
Revision: 13110009 Serial number: 0008962397
Coding: 0404B5
Shop #: WSC 00066 790 00086
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
ROD: EV_TSGFPQ35BRFVW46X_VW32.rod
VCID: 5BB5226B5225895E37-800E
Slave Driver:
Subsystem 1 - Part No SW: 6R0 959 811 M HW: 6R0 959 811 M
Component: J388__TSG_HL 006 5460
Serial number: 14102587141007121138
Coding: 000000
1 Fault Found:
131584 - Motor for Rear Window Regulator
B11EE 54 [009] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 76
Mileage: 39813 km
Date: 2022.06.04
Time: 21:49:21
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 68 3501
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 397998E370599B4E05-806C
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0515
Revision: 15110009 Serial number: 0008977044
Coding: 0404B4
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X_VW32.rod
VCID: 5CB72177572B8E663E-8008
Slave Passenger:
Subsystem 1 - Part No SW: 6R0 959 812 M HW: 6R0 959 812 M
Component: J389__TSG_HR 006 5460
Serial number: 14102586141006155832
Coding: 000000
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 76
Mileage: 39813 km
Date: 2022.06.04
Time: 21:49:21
Address 56: Radio
Cannot be reached
Direksiyon kablosunu değiştirmediyseniz tuşlar çaluşmaz.
