Chassis Type: 16-VW32 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ16ZFM036691 Mileage: 123000km-76428miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 RH HW: 03L 907 425 C
Component: 1,6l R4 CR td H43 0248
Revision: --H43--- Serial number: 00000000000000
Coding: 10254014032400080000
Shop #: WSC 00066 790 00012
ASAM Dataset: EV_ECM16TDI02103L906023RH 003002
ROD: EV_ECM16TDI02103L906023RF.rod
VCID: 7DF14FF6ECF168AC73-8028
No fault code found.
Readiness: 1110 1000
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 062 D HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6201
Revision: 00043014 Serial number: CU501501246956
Coding: 0000020
Shop #: WSC 44551 111 44551
VCID: 2D51BFB6B411382C83-8078
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: A43B40F809250000251102ED901A0041A5180011
Shop #: WSC 00066 123 12345
VCID: 04073A12871B19643C-8050
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 1K8 907 426 K HW: 1K8 907 426 K
Component: AC Manuell H20 0707
Revision: 00001002
Coding: 0008004802
Shop #: WSC 00066 123 00119
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: EV_ACManueBHBVW36X_VW32.rod
VCID: 3B7581EEB265A69C0D-806E
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 087 AC HW: 5K0 937 087 AC
Component: BCM PQ35 H+ 122 0174
Revision: BF122001
Coding: 2600003800AF00DC40980000000000E407008C885280C1205C0028000040
VCID: 76E350DAC1C73BF432-8022
2 Faults Found:
02745 - Bulb for Daytime Running Light; Left
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 75
Mileage: 123002 km
Time Indication: 0
Date: 2020.04.26
Time: 18:56:46
Freeze Frame:
Term 15 On
Voltage: 11.85 V
ON
ON
OFF
OFF
OFF
02746 - Bulb for Daytime Running Light; Right
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 75
Mileage: 123002 km
Time Indication: 0
Date: 2020.04.26
Time: 18:56:46
Freeze Frame:
Term 15 On
Voltage: 11.85 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5C0 959 655 F HW: 5C0 959 655 F
Component: AirbagVW10 014 0613
Serial number: 003JQM0608PN
Coding: 0000504A
ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 356197D6944170ECFB-8060
Crash sensor for side airbag: driver side:
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H02 ----
Serial number: 3572MSME7506294EZZZ/
Crash sensor for side airbag: front passenger side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H02 ----
Serial number: 3582MSME740E294EZZZ5
Crash sensor for side airbag: rear: driver side:
Subsystem 3 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.H H02 ----
Serial number: 3516KSME445A5134ZZZP
Crash sensor for side airbag: rear: passenger side:
Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.H H02 ----
Serial number: 3526KSME385A5134ZZZT
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 5K0 953 521 DQ HW: 5K0 953 569 AH
Component: LENKS.MODUL 016 0140
Revision: FF010042 Serial number: 20140529200074
Coding: 000210000A
Shop #: WSC 27849 002 104857
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 7EF348FAE1F773B46A-802A
Multifunction steering wheel control module:
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5C6 920 874 A HW: 5C6 920 874 A
Component: KOMBI H05 0906
Coding: 170B01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04727
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 2D51BFB67C11382C83-8078
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AP HW: 7N0 907 530 AK
Component: J533 Gateway H57 1653
Revision: H57 Serial number: 09031503000163
Coding: 351002
VCID: 7EF348FAE9F773B46A-802A
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 0906
Serial number:
Coding: 000000
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADB74AA8D7FEF14A6-803E
Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0515
Revision: 13110009 Serial number: 0009367861
Coding: 0400B5
Shop #: WSC 00066 790 00083
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
ROD: EV_TSGFPQ35BRFVW46X_VW32.rod
VCID: 5BB5216E5225869C2D-800E
Slave Driver:
Subsystem 1 - Part No SW: 6R0 959 811 M HW: 6R0 959 811 M
Component: J388__TSG_HL 006 5460
Serial number: 14202587150223092529
Coding: 000000
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 69 3501
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 39799BE67059948C1F-806C
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0515
Revision: 15110009 Serial number: 0009351279
Coding: 0404B5
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X_VW32.rod
VCID: 5CB72272572B81A424-8008
Slave Passenger:
Subsystem 1 - Part No SW: 6R0 959 812 M HW: 6R0 959 812 M
Component: J389__TSG_HR 006 5460
Serial number: 14102586150218135638
Coding: 000000
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 B HW: 5K0 035 190 B
Component: Radio RCD510 006 0236
Revision: 00000001 Serial number: VWZ1Z3P0406954
Coding: 05000400040006
Shop #: WSC 01357 011 00200
VCID: 24475A9227DBF9645C-8070
Hatayı ve kodları gönderdim sanırım bende adaptasyon bölümü yoktur. Gökhan Beyin dediği gibi sadece coding bölümü vardır.
