Vag.com Kodlamada Başlangıç, Yedekleme, Döküman ve Kodlama Sonrası Geri Almak
@PassificGolf7 Virus korumasinda Vcds klasorunu dislamalar'a ekleyin, orayi kontrol etmez, loader inyujkedikten sonra isterseniz sadece loader i da dislamalar'a ekleyip sonra klasör'u kaldirabilirsiniz.
Monday,12,April,2021,16:12:51:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.0.1
Data version: 20200331 DS317.0
www.Ross-Tech.com
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: WVWZZZAUZXXXXXXX3   Mileage: 23770km-14769miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
   Alternator:
   Multi Function Steering Wheel Control Module:
   Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0103
   Serial number: 29150002309050085474
   Coding: 29FFFF
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 G    HW: 5Q0 915 181 G
   Component: J367-BDMHella  H04 8050
   Serial number: 4249528403
1 Fault Found:
66052 - Infotainment CAN Bus (SAE Bus E)
          U0065 00 [008] - Performance
          [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 17
                    Mileage: 23617 km
                    Date: 2021.03.27
                    Time: 12:05:15
                    Supply voltage: Terminal 30: 12.1 V
                    Terminal 15: OFF
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q0 959 593 E    HW: 5Q0 959 593 B
   Component: TSG FS        020 0041
   Serial number: 300915BIT22865
   Coding: 003B0320D000040000001000
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 4385FA0BCA95D19E5F-8016
   Drivers Door Rear Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 811     HW: 5Q0 959 811   Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  005 0005
   Serial number: 00000000000008170020
   Coding: 110000
1 Fault Found:
65588 - Motor for Window Regulator
          B1487 54 [008] - Missing Calibration / Basic Setting
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 25
                    Mileage: 23747 km
                    Date: 2021.04.07
                    Time: 15:20:42
Arkadaşlar,
Dün Kablom geldikten sonra Bazı kodlar yapmıştım.
Tabi yapmadan önce Auto-Scan Yapıp kaydetmiştim.
Şimdi ne imiş bir bakayım dedim.
İlk baştaki maddelerin geneli OK iken 2 tanesi değil?
Bunlar hatamıdır? Nasıl düzeltilir? Ne yapabilirim?
Yine yukarıda verdiğim yedek txt belgesinde aşağı doğru indiğimde 2 tane hata bulundu diyor.
Ne yapabilirim?
Bu TXT belgesi hiçbir işlem yapılmadan alınan Auto-Scandır.
@Terms 42 sol ön kapıda cam kaldırma motoru hata vermiş bazı araçlarda cam sıkışmalarında veriyor veriyor
19 Can getaway media kısmında vermiş herhangibir cihaz bağladınızmı orjinal media haricinde
@oryx Hayır. Arabada fabrikanın taktığı dışında 4 lastik ve akü var.
Geri kalan herşey orjinal
@oryx
Bu hataları ben düzeltebilir miyim?
Servise ziyaret mi gerekiyor?
edit; Üstteki kendi mesajım eklenmiş onu sildim
Ailemizin vag cı yazılımcıları. @zulalyol@CemK @forjust1day@MeetGarage ve adını yazamadığım arkadaşlar.
Yokmu bir bilgi?
Ben düzeltebilirmiyim? servisemi gitmeliyim?
Yada hatayı silebilirmiyim?
@Terms Vag ile cogu hatanın detayini goremezsiniz, medya için bi hata vermiş ama ne oldugu belli degil.
Cam motoru kalibrasyon hatasi vermis, muhtemelen camın birinde tek basma ile acma kapama calismiyor su anda. Normalde kalibre kolay ama vag yaparmi emin değilim.
@CemK Cem hocam 1 hafta kadar önce tek basma çalışmıyordu, bunun kalibrasyonunu servis capı kapat sonuna kadar ve kapandıktan sonra 3sn daha bele demişti
yaptım düzeldi. Şuan tek basma çalışıyor.
@CemK Saat belitirseniz o satte müsait olurum Hocam
@CemK VCDS ile silinebiliyormu Hocam?
