Vag.com Kodlamada Başlangıç, Yedekleme, Döküman ve Kodlama Sonrası Geri Almak
Log dosyasini okumada sıkıntı cekiyorum, anliyamiorum daha dogrusu.
Bu kod arizalardan sona aldigim log verisi
Thursday,12,May,2016,21:33:33:60543
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.4.1
Data version: 20160216
www.Ross-Tech.com
VIN: WVWZZZAUZGW149273 License Plate: 34NG6374
Mileage: 8690km-5399mi Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZGW149273 Mileage: 8690km-5399miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CYVB) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 027 GR HW: 04E 907 309 BL
Component: R4 1.2l TFS H23 2394
Revision: R4H23---
Coding: 01190012230411082000
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_ECM12TFS01104E906027GR 001005
ROD: EV_ECM12TFS01104E906027GR_AU37.rod
VCID: 7A97F2DD67958C509A-802E
1 Fault Found:
7150 - Implausible Data Received from Steering Angle Sensor Module (G85)
U0428 00 [036] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 8690 km
Date: 2016.05.12
Time: 00:00:15
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 3Q0 907 379 AA HW: 3Q0 907 379 F
Component: ESC H42 0623
Revision: 00000000 Serial number: 92655000001776
Coding: 01FA6AA1142429750779060741C62580562894E06082A4F300200078C002
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
ROD: EV_Brake1UDSContiMK100IPB_VW37.rod
VCID: 7996F0DA6398925BA2-802C
4 Faults Found:
0297 - Steering angle sensor
B1168 16 [008] - Voltage Too Low
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 123
Mileage: 8690 km
Date: 2016.05.12
Time: 00:00:16
16401 - Tire Pressure Warning
C102D 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 193
Mileage: 4125 km
Date: 2016.02.11
Time: 15:00:21
16412 - Display for Tire Pressure Monitoring
C1146 02 [008] - Signal Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 123
Mileage: 8690 km
Date: 2016.05.12
Time: 00:00:26
16413 - Display for Tire Pressure Monitoring
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 123
Mileage: 8690 km
Date: 2016.05.12
Time: 00:00:26
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5G0 907 044 BC HW: 5G0 907 044 BC
Component: Climatronic H03 1001
Revision: 00001K08
Coding: 00020004200100001005000012101402
ASAM Dataset: EV_ACClimaBHBVW37X 004131
ROD: EV_ACClimaBHBVW37X_SK37.rod
VCID: 6986100A23C8F2CB22-803C
1 Fault Found:
459015 - Databus
U1121 00 [008] - Missing Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 120
Mileage: 8648 km
Date: 2016.05.11
Time: 19:29:29
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 AQ HW: 5Q0 937 084 AL
Component: BCM MQBAB M H24 0175
Serial number: 01061528101189
Coding: 03000842C24100DB4BE44000000403081000000000000000000000000000
ASAM Dataset: EV_BCMMQB 015001
ROD: EV_BCMBOSCH_AU37.rod
VCID: 0718DC74ABD63E7532-8052
Slave 1:
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 150918 043 0551
Serial number: 150930025008
Coding: 0E4DDD
No fault code found.
Address 15: Airbags (J234) Labels: 5Q0-959-655.clb
Part No SW: 5Q0 959 655 D HW: 5Q0 959 655 D
Component: AirbagVW20 015 0388
Serial number: 003F6R14Y2W
Coding: 98CCC000000000005C0000CF004800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002130
ROD: EV_AirbaVW20SMEVW37X_AU37.rod
VCID: 415E608283B0E2E362-8014
Crash sensor for side airbag; driver side:
Subsystem 1 - Part No SW: ----------- HW: 480 000 110 15
Component: SideSensor_Df 001 0887
Serial number: 3576700000054B2D861Z
Coding: 2D2D2D
Crash sensor for side airbag; front passenger side:
Subsystem 2 - Part No SW: ----------- HW: 480 000 110 15
Component: SideSensor_Pf 001 0887
Serial number: 3586700000066471271K
Coding: 2D2D2D
Crash sensor for side airbag; rear; driver side:
Subsystem 3 - Part No SW: ----------- HW: 480 400 510 15
Component: SideSensor_Dr 001 6149
Serial number: 3516502A71CCEA04A17O
Coding: 2D2D2D
Crash sensor for side airbag; rear; passenger side:
Subsystem 4 - Part No SW: ----------- HW: 480 400 510 15
Component: SideSensor_Pr 001 6149
Serial number: 3526502A51CCEA02F10J
Coding: 2D2D2D
Crash sensor for front airbag; driver side:
Subsystem 5 - Part No SW: ----------- HW: 480 403 009 15
Component: FrontSensor_D 001 6149
Serial number: 3556502A91CCEA04409P
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 FT HW: 5Q0 953 549 F
Component: Lenks. Modul 003 0110
Revision: -------- Serial number: 05101504401070
Coding: 0400
ASAM Dataset: EV_SMLSKLOMQB 017001
ROD: EV_SMLSKLOMQB_SE37.rod
VCID: 0D22C866D3B41A4F02-8058
Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
Part No SW: 5G1 920 740 A HW: 5G1 920 740 A
Component: KOMBI 202 6420
Coding: 07A51A002380000801082A001400000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009046
ROD: EV_DashBoardVDDMQBAB_AU37.rod
VCID: 243DA6DB3F27902E4A-8070
Address 19: CAN Gateway (J533) Labels: 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AE HW: 5Q0 907 530 E
Component: GW MQB Mid 127 1223
Revision: -------- Serial number: 0003998664
Coding: 030100043F085700FB000248080F00010001050000000000000000000000
ASAM Dataset: EV_GatewLear 013020
ROD: EV_GatewLear.rod
VCID: 748D062B7FB7B07ECA-8020
Alternator:
Multifunction unit control module:
Subsystem 2 - Part No SW: 5G0 959 442 H HW: 5G0 959 442 H
Component: E221__MFL-DC1 H17 0103
Serial number: 29150001845100065382
Coding: 24FFFF
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 2379298003
Address 42: Door Elect, Driver (J386) Labels: 5QX-959-X93-42.clb
Part No SW: 5Q0 959 393 E HW: 5Q0 959 393 B
Component: TSG FS 020 0041
Serial number: 190915BII07234
Coding: 003003208000040000001000
ASAM Dataset: EV_DCUDriveSideEWMINKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811
Component: FOND_FHSG_DRV 005 0005
Serial number: 00000000000007477204
Coding: 110000
Address 44: Steering Assist (J500) Labels: 5Q0-909-144.clb
Part No SW: 5Q0 909 144 S HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1063
Coding: 0103
ASAM Dataset: EV_SteerAssisMQB 012140
ROD: EV_SteerAssisMQB.rod
VCID: 445D66BBBF87D0CE4A-8010
Address 52: Door Elect, Pass. (J387) Labels: 5QX-959-X92-52.clb
Part No SW: 5Q0 959 392 E HW: 5Q0 959 392 B
Component: TSG BFS 020 0041
Serial number: 050915BI422145
Coding: 003001208C00040000801000
ASAM Dataset: EV_DCUPasseSideEWMINKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
VCID: 40516E8F8FBBE8EA6A-8014
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812
Component: FOND_FHSG_PSG 005 0005
Serial number: 00000000000007495769
Coding: 090000
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 5G0 035 869 A HW: 5G0 035 869 A
Component: MU-E--ER 851 6490
Serial number: 18091500010093
Coding: 02730000FF00000041110001000100001F0000840000010000
ASAM Dataset: EV_MUEnt4CGen2LGE 001025
ROD: EV_MUEnt4CGen2LGE_VW26.rod
VCID: 2C4596C35F1F60760A-8078
End-------------------------(Elapsed Time: 07:28)--------------------------
Centrel elk. kısmında long codingde byte 0 da bit 0-1 deki kısımı Left driver olarak ayarlayın yani açılan pencerede en üstteki 00 yazan kodu kaydetin
Necati allah razi olsun far sensorum ve yagmur sensorude tamamladim kapilarda normale dondu sis farida calisti cok sagol kardesim cok tsk ederim simdi allahin izniyle rahat uyuyabilirim :)
Orhan Hoca dedi:
çok iyi hocam. biz de sevindik bu duruma. :'(
Orhan hocam peki bu sensoru ve anahtari kodladiktan sonra cominghome ve leawinghome ozelligi acilabiliyormu?
Dun gec saatte denedim fakat otomatik olarak calistiramadim forumdaki kodlamalarla. Teyp menusunde cominghome ayari geldi fakat hizmet disi yaziyor
Değerli Hocam,fabrika ayarları menüsünden "Işık Ayarlarını" fabrika ayarlarına döndürmeniz gerekmekte.
Bunu yaptığınızda düzelecektir.
Değerli Hocam,fabrika ayarları menüsünden "Işık Ayarlarını" fabrika ayarlarına döndürmeniz gerekmekte. Bunu yaptığınızda düzelecektir.
Teyp menusunden isik ayarlarina girip ordan fabrika ayarlarini sececegim dogrumu anlamisim.
Medya ekranında "Car" tuşuna basın. Sağ alttan ayarlara girin. En altta "Fabrika ayarları" na girin. "Işık" sekmesini fabrika ayarlarına döndürün. [emoji4]
[emoji106] cok tesekkur ederim ogle arasinda hemen deneyecegim sonuc ile alakali donus yaparim :)
Coming home ile alakalı olacağını sanmıyorum. Menüden baktınız mı parlaklığına.
Menuden actim parlakligini ama 2x5 watt isaretledim aydinlatma lambalarini acaba farkli bir secenekmi secmeliydim
